RSP0720 0 Report post Posted December 4, 2013 Help! The sound only works on Chrome for a while after I uninstall and reinstall. The sound/volume Mixer has little red circle/slash at the bottom. If I click on the circle it pops right back, blocking the sound. Any ideas out there? Thanks, Roberta Share this post Link to post Share on other sites
cwsnyder2 55 Report post Posted December 6, 2013 What site(s) are you attempting to access where this happens? Also which operating system and computer are you using? I am presently using Google's Chrome browser with no such problems. Share this post Link to post Share on other sites
Dustin 0 Report post Posted December 22, 2013 Every so often I get that on Google chrome and the best way to get rid of your problem is left click on the speaker icon and then you will notice a bar comes up and usually about 99% of the time if you raise or lower the bar your problem goes away. Dustin [8] Share this post Link to post Share on other sites
