Jump to content
Sign in to follow this
HulaGal
IE 11 update caused problem
Recommended Posts
After the latest update, I now cannot type in passwords on sites requiring them. I'm thinking uninstalling and reinstalling IE11 may help. Can someone please tell me how to do this or suggest alternate solution. Thank you.
Share this post
Link to post
Share on other sites
If this is occurring on several sites, try deleting all your cookies and temp files. Click on Tools>Internet options>General tab. Click Delete under Browsing History. Also, check Delete Browsing History on Exit. Close and restart IE.
It could be an add-on problem. Go to Tools>Manage add-ons. Highlight and disable each enabled add-on one at a time, and see it that fixes the problem.
If not, you can try resetting IE. Go to Tools>Internet Options>Advanced tab. At the bottom click on Reset under Reset Internet Explorer Settings, then close and restart IE.
Share this post
Link to post
Guest
This topic is now closed to further replies.
-advertisement-
