Jump to content
Sign in to follow this
tnt92fox
W10 USB recovery drive
Recommended Posts
When I try to create a recovery drive, I get an error message that windows cannot create a recovery drive...some required files are missing. How to fix?
I created a recovery drive about 1-1/2 years ago, but now get the error message. I tried sfc/scannow but no issues were found.
Share this post
Link to post
Share on other sites
I've encountered something similar and there is no easy way to fix it. Somehow Windows loses track of where it's install files are especially after installing a major update. You can dig around and try to figure out how to fix it but I couldn't get it to work. I had to use Windows Media Creator Tool and make a Windows 10 Install USB of the last major update of WIndows, which was the Creators Update, backup my data and reinstall. After that, I ran Windows update to get any current updates and then Created a recovery drive and it worked. It's a bit of a chore, but I at least have a more recent Windows recovery. There are also third party options back up your Windows installation but it probably will not fix your "Create a recovery drive" problem.
Share this post
Link to post
-advertisement-
